ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / GetPointCount Method
    GetPointCount Method (LasDataset)
    Gets the number of points in this LAS dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetPointCount() As Double
    public double GetPointCount()
    Return Value
    The number of points in this LAS dataset.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
