ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / GetSurfaceConstraintCount Method
Example
    GetSurfaceConstraintCount Method (LasDataset)
    Gets the number of surface constraints used in this LAS dataset. Also see GetSurfaceConstraints. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSurfaceConstraintCount() As Integer
    public int GetSurfaceConstraintCount()
    Return Value
    The number of surface constraints used in this LAS dataset.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get Surface Constraint information from a LAS Dataset
      var constraintCount = lasDataset.GetSurfaceConstraintCount();
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.SurfaceConstraint> constraints = lasDataset.GetSurfaceConstraints();
      foreach (var constraint in constraints)
        var dsName = constraint.DataSourceName;
        var wksPath = constraint.WorkspacePath;
        var heightField = constraint.HeightField;
        var surfaceType = constraint.SurfaceType;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
