ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / GetUniqueClassCodes Method
Example
    Gets the set of classification codes used in this LAS dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetUniqueClassCodes() As IReadOnlyList(Of Integer)
    public IReadOnlyList<int> GetUniqueClassCodes()
    Return Value
    The set of class codes used in this LAS dataset.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get classification codes / Returns from a LAS Dataset
      var classCodes = lasDataset.GetUniqueClassCodes();
      var returns = lasDataset.GetUniqueReturns();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
