ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / GetVersion Method
    GetVersion Method (LasDataset)
    Gets the major and minor version of the LAS dataset. Also retrieves the point format. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Return Value
    The Major and minor version of the LAS Dataset along with the point format.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
