ArcGIS.Core.Data.Analyst3D Namespace / LasDatasetDefinition Class / GetExtent Method
Example
    GetExtent Method (LasDatasetDefinition)
    Gets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that is contained by the LasDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetExtent() As Envelope
    public Envelope GetExtent()
    Return Value
    An ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that is contained by the LasDataset.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Retrieve dataset objects
      //Note: Needs QueuedTask to run
        using (var tin = tinLayer.GetTinDataset())
          using var tinDef = tin.GetDefinition();
          Envelope extent = tinDef.GetExtent();
          SpatialReference sr = tinDef.GetSpatialReference();
        using (terrain = terrainLayer.GetTerrain())
          using var terrainDef = terrain.GetDefinition();
          Envelope extent = terrainDef.GetExtent();
          SpatialReference sr = terrainDef.GetSpatialReference();
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          using var lasDatasetDef = lasDataset.GetDefinition();
          Envelope extent = lasDatasetDef.GetExtent();
          SpatialReference sr = lasDatasetDef.GetSpatialReference();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
