ArcGIS.Core.Data.Analyst3D Namespace / LasDatasetDefinition Class / GetSpatialReference Method
Example
    GetSpatialReference Method (LasDatasetDefinition)
    Gets the ArcGIS.Core.Geometry.SpatialReference for the LasDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSpatialReference() As SpatialReference
    public SpatialReference GetSpatialReference()
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Retrieve dataset objects
      //Note: Needs QueuedTask to run
        using (var tin = tinLayer.GetTinDataset())
          using var tinDef = tin.GetDefinition();
          Envelope extent = tinDef.GetExtent();
          SpatialReference sr = tinDef.GetSpatialReference();
        using (terrain = terrainLayer.GetTerrain())
          using var terrainDef = terrain.GetDefinition();
          Envelope extent = terrainDef.GetExtent();
          SpatialReference sr = terrainDef.GetSpatialReference();
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          using var lasDatasetDef = lasDataset.GetDefinition();
          Envelope extent = lasDatasetDef.GetExtent();
          SpatialReference sr = lasDatasetDef.GetSpatialReference();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
