ArcGIS.Core.Data.Analyst3D Namespace / LasPoint Class / ScanAngleDegree Property
    Gets the scan angle of this point in degrees. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property ScanAngleDegree As Double
    public double ScanAngleDegree {get;}
    Remarks
    The scan angle represents the rotational position of the emitted laser pulse with respect to the vertical of the coordinate system of the data. Each increment represents 0.006 degrees.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
