ArcGIS.Core.Data.Analyst3D Namespace / LasPoint Class / ScanAngleRank Property
    Gets the scan angle rank of this point. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property ScanAngleRank As Short
    public short ScanAngleRank {get;}
    Remarks
    The scan angle rank is the angle (rounded to the nearest integer) at which the laser point was output from the laser system including the roll of the aircraft. The scan angle is within 1 degree of accuracy from +90 to -90 degrees.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
