ArcGIS.Core.Data.Analyst3D Namespace / Terrain Class / GetTileProperties Method
Example
    Gets the tile properties of the terrain. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public TerrainTileProperties GetTileProperties()
    Public Function GetTileProperties() As TerrainTileProperties
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get Tile Information from a Terrain
      var tileInfo = terrainDataset.GetTileProperties();
      var colCount = tileInfo.ColumnCount;
      var rowCount = tileInfo.RowCount;
      var tileSize = tileInfo.TileSize;
      var tileCount = tileInfo.TileCount;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
