ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetDefinition Method
Example
    GetDefinition Method (TinDataset)
    Gets the TinDatasetDefinition of this TIN dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shadows Function GetDefinition() As TinDatasetDefinition
    public new TinDatasetDefinition GetDefinition()
    Return Value
    The TinDatasetDefinition of this TIN dataset.
    Example
    Retrieve dataset objects
      //Note: Needs QueuedTask to run
        using (var tin = tinLayer.GetTinDataset())
          using var tinDef = tin.GetDefinition();
          Envelope extent = tinDef.GetExtent();
          SpatialReference sr = tinDef.GetSpatialReference();
        using (terrain = terrainLayer.GetTerrain())
          using var terrainDef = terrain.GetDefinition();
          Envelope extent = terrainDef.GetExtent();
          SpatialReference sr = terrainDef.GetSpatialReference();
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          using var lasDatasetDef = lasDataset.GetDefinition();
          Envelope extent = lasDatasetDef.GetExtent();
          SpatialReference sr = lasDatasetDef.GetSpatialReference();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
