ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetExtent Method
    GetExtent Method (TinDataset)
    Gets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that has been stored in the TinDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetExtent() As Envelope
    public Envelope GetExtent()
    Return Value
    An ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that has been stored in the TinDataset.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
