ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetFullExtent Method
    Gets the full 2D-extent of the user-supplied data in the TIN including NODATA nodes. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetFullExtent() As Envelope
    public Envelope GetFullExtent()
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    Returns the miminum bounding rectangle (2D) that surrounds all user-supplied data in the TIN, including data outside the interpolation zone.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
