ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetIsEmpty Method
Example
    GetIsEmpty Method
    Gets if the TIN is empty. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetIsEmpty() As Boolean
    public bool GetIsEmpty()
    Return Value
    A boolean indicating if the TIN is empty.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Tin Properties
      var isEmpty = tinDataset.GetIsEmpty();
      var hasHardEdges = tinDataset.HasHardEdges();
      var hasSoftEdges = tinDataset.HasSoftEdges();
      var isConstrainedDelaunay = tinDataset.UsesConstrainedDelaunay();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
