ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetNaturalNeighbors Method
Point location. This will be projected into the spatial reference of the TIN dataset.
Example
    Gets the set of nodes that are the natural neighbors of the specified point. The natural neighbors of a point are the nodes it would connect with to form triangles if it were inserted in the triangulation. They are the closest surrounding nodes in all directions. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetNaturalNeighbors( _
       ByVal point As MapPoint _
    ) As IReadOnlyList(Of TinNode)
    public IReadOnlyList<TinNode> GetNaturalNeighbors(
       MapPoint point
    Parameters
    point
    Return Value
    A IReadOnlyList of TinNode
    Exceptions
    ExceptionDescription
    Point is null
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    If the input point is outside of the TIN or empty, then an empty list is returned.
    Example
    Access TIN Elements by MapPoint
      // "identify" the closest node, edge, triangle
      using (var nearestNode = tinDataset.GetNearestNode(mapPoint))
        // do something with the node
      using (var nearestEdge = tinDataset.GetNearestEdge(mapPoint))
        // do something with the edge
      using (var triangleByPoint = tinDataset.GetTriangleByPoint(mapPoint))
        // do something with the triangle
      // get the set of natural neighbors
      // (set of nodes that "mapPoint" would connect with to form triangles if it was added to the TIN)
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinNode> naturalNeighbors = tinDataset.GetNaturalNeighbors(mapPoint);
      // get the set of triangles whose circumscribed circle contains "mapPoint"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinTriangle> triangles = tinDataset.GetTriangleNeighborhood(mapPoint);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
