ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetZFactor Method
    GetZFactor Method
    Gets the Z unit conversion factor for this TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetZFactor() As Double
    public double GetZFactor()
    Return Value
    The z unit conversion factor for this TIN.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
