ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / HasEdgeTags Method
    HasEdgeTags Method
    Gets if any edges have tags in this TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function HasEdgeTags() As Boolean
    public bool HasEdgeTags()
    Return Value
    True if any edges have tags.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    Tag values can be set to whatever the user wishes and their interpretation is left up to the user.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
