ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / HasSoftEdges Method
Example
    HasSoftEdges Method
    Gets if there are any soft edges in this TIN. Hard and soft edges are enforced in the triangulation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function HasSoftEdges() As Boolean
    public bool HasSoftEdges()
    Return Value
    True if any edges are soft.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Tin Properties
      var isEmpty = tinDataset.GetIsEmpty();
      var hasHardEdges = tinDataset.HasHardEdges();
      var hasSoftEdges = tinDataset.HasSoftEdges();
      var isConstrainedDelaunay = tinDataset.UsesConstrainedDelaunay();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
