ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / And Class / And Constructor
The left expression.
The right expression.
Example
    And Constructor
    Initializes a new instance of the And class.
    Syntax
    Parameters
    leftExpression
    rightExpression
    Example
    Create a Condition to compare a Network Attribute against a set of values
      static void CreateNetworkAttributeComparison(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
        // This routine creates a NetworkAttributeComparison to compare the Lifecycle network attribute against two values: "In Design" and "In Service"
        const int InDesign = 4;
        const int InService = 8;
        // Create a NetworkAttribute object for the Lifecycle network attribute from the UtilityNetworkDefinition
        using NetworkAttribute lifecycleNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Lifecycle");
        // Create a NetworkAttributeComparison that stops traversal if Lifecycle <> "In Design" (represented by the constant InDesign)
        NetworkAttributeComparison inDesignNetworkAttributeComparison =
          new NetworkAttributeComparison(lifecycleNetworkAttribute, Operator.NotEqual, InDesign);
        // Create a NetworkAttributeComparison to stop traversal if Lifecycle <> "In Service" (represented by the constant InService)
        NetworkAttributeComparison inServiceNetworkAttributeComparison =
          new NetworkAttributeComparison(lifecycleNetworkAttribute, Operator.NotEqual, InService);
        // Combine these two comparisons together with "And"
        And lifecycleFilter = new And(inDesignNetworkAttributeComparison, inServiceNetworkAttributeComparison);
        // Final condition stops traversal if Lifecycle <> "In Design" and Lifecycle <> "In Service"
        traceConfiguration.Traversability.Barriers = lifecycleFilter;
    Requirements
