ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / DownstreamTracer Class
Members Example
    The DownstreamTracer class performs a downstream trace.
    Object Model
    DownstreamTracer ClassUtilityNetwork Class
    Syntax
    Public Class DownstreamTracer
       Inherits Tracer
    public class DownstreamTracer : Tracer
    Remarks
    For subnetworks with sources, downstream is defined as paths that do not lead to a source. For subnetworks with sinks, downstream is defined as paths that lead to a sink.
    Example
    Create a DownstreamTracer
      // This routine creates a DownstreamTracer object from a UtilityNetwork
      static void CreateADownstreamTracerObject(UtilityNetwork utilityNetwork)
        using TraceManager traceManager = utilityNetwork.GetTraceManager();
        DownstreamTracer downstreamTracer = traceManager.GetTracer<DownstreamTracer>();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.UtilityNetwork.Trace.Tracer
          ArcGIS.Core.Data.UtilityNetwork.Trace.DownstreamTracer
    Requirements
