ArcGIS.Core.Data.Analyst3D Namespace / TinEdge Class / EdgeType Property
Example
    EdgeType Property (TinEdge)
    Gets the type of this TIN edge. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property EdgeType As TinEdgeType
    public TinEdgeType EdgeType {get;}
    Remarks
    The type of an edge indicates whether or not it's an enforced breakline edge. If it's enforced the type will be equal to either TinEdgeType.HardEdge or TinEdgeType.SoftEdge. If it's not a breakline edge the type will equal TinEdgeType.RegularEdge.
    Example
    TIN Edges
      // nodes of the edge
      var nodes = edge.Nodes;
      // edge geometry
      polyline = edge.ToPolyline();
      // edge length
      var length = edge.Length;
      // is the edge "inside"
      var isInsideEdge = edge.IsInsideDataArea;
      // edge type - regular/hard/soft
      var edgeType = edge.EdgeType;
      // get next (clockwise) edge in the triangle
      var nextEdge = edge.GetNextEdgeInTriangle();
      // get previous (anti-clockwise) edge in the triangle
      var prevEdge = edge.GetPreviousEdgeInTriangle();
      // get opposite edge
      var oppEdge = edge.GetNeighbor();
      // get left triangle
      var leftTriangle = edge.LeftTriangle;
      // get right triangle
      var rightTriangle = edge.RightTriangle;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
