ArcGIS.Core.Data.Analyst3D Namespace / TinEdge Class / Length Property
Example
    Length Property (TinEdge)
    Gets the length of this TIN edge. The length is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public override double Length {get;}
    Public Overrides NotOverridable ReadOnly Property Length As Double
    Example
    TIN Edges
      // nodes of the edge
      var nodes = edge.Nodes;
      // edge geometry
      polyline = edge.ToPolyline();
      // edge length
      var length = edge.Length;
      // is the edge "inside"
      var isInsideEdge = edge.IsInsideDataArea;
      // edge type - regular/hard/soft
      var edgeType = edge.EdgeType;
      // get next (clockwise) edge in the triangle
      var nextEdge = edge.GetNextEdgeInTriangle();
      // get previous (anti-clockwise) edge in the triangle
      var prevEdge = edge.GetPreviousEdgeInTriangle();
      // get opposite edge
      var oppEdge = edge.GetNeighbor();
      // get left triangle
      var leftTriangle = edge.LeftTriangle;
      // get right triangle
      var rightTriangle = edge.RightTriangle;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
