ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / NetworkAttributeComparison Class / NetworkAttributeComparison Constructor / NetworkAttributeComparison Constructor(NetworkAttribute,Operator,Object)
The NetworkAttribute to use in the comparison.
The Operator to use (equals, less than, etc.).
The specific value that the NetworkAttribute should be compared against. This value cannot be null.
Example
    Initializes a new instance of the NetworkAttributeComparison class.
    Syntax
    Public Function New( _
       ByVal networkAttribute As NetworkAttribute, _
       ByVal comparisonOperator As Operator, _
       ByVal value As Object _
    public NetworkAttributeComparison(
       NetworkAttribute networkAttribute,
       Operator comparisonOperator,
       object value
    Parameters
    networkAttribute
    comparisonOperator
    value
    Example
    Create a Condition to compare a Network Attribute against a set of values
      static void CreateNetworkAttributeComparison(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
        // This routine creates a NetworkAttributeComparison to compare the Lifecycle network attribute against two values: "In Design" and "In Service"
        const int InDesign = 4;
        const int InService = 8;
        // Create a NetworkAttribute object for the Lifecycle network attribute from the UtilityNetworkDefinition
        using NetworkAttribute lifecycleNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Lifecycle");
        // Create a NetworkAttributeComparison that stops traversal if Lifecycle <> "In Design" (represented by the constant InDesign)
        NetworkAttributeComparison inDesignNetworkAttributeComparison =
          new NetworkAttributeComparison(lifecycleNetworkAttribute, Operator.NotEqual, InDesign);
        // Create a NetworkAttributeComparison to stop traversal if Lifecycle <> "In Service" (represented by the constant InService)
        NetworkAttributeComparison inServiceNetworkAttributeComparison =
          new NetworkAttributeComparison(lifecycleNetworkAttribute, Operator.NotEqual, InService);
        // Combine these two comparisons together with "And"
        And lifecycleFilter = new And(inDesignNetworkAttributeComparison, inServiceNetworkAttributeComparison);
        // Final condition stops traversal if Lifecycle <> "In Design" and Lifecycle <> "In Service"
        traceConfiguration.Traversability.Barriers = lifecycleFilter;
    Requirements
