// This routine creates a Propagator to propagate the Phases Normal network attribute downstream during a trace
static void CreatePropagator(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
const int ABCPhase = 7;
// Get a NetworkAttribute object for the Phases Normal attribute from the UtilityNetworkDefinition
using NetworkAttribute normalPhaseAttribute = utilityNetworkDefinition.GetNetworkAttribute("Phases Normal");
// Create a propagator to propagate the Phases Normal attribute downstream from the source, using a Bitwise And function
// Allow traversal to continue as long as the Phases Normal value includes any of the ABC phases
// (represented by the constant ABCPhase)
Propagator phasePropagator = new Propagator(normalPhaseAttribute, PropagatorFunction.BitwiseAnd,
Operator.IncludesAny, ABCPhase);
// Assign this propagator to our trace configuration
traceConfiguration.Propagators = new List<Propagator>() { phasePropagator };
System.Object
ArcGIS.Core.Data.UtilityNetwork.Trace.Propagator
