ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / GetDegree Method
When set to TRUE only the number of connected edges that are classified as either hard or soft is returned. When set to FALSE all edges are used regardless of type.
    GetDegree Method
    Gets the degree of this TIN node. The degree of a node is the number of edges that are connected to it. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDegree( _
       ByVal enforceEdgesOnly As Boolean _
    ) As Integer
    public int GetDegree(
       bool enforceEdgesOnly
    Parameters
    enforceEdgesOnly
    Return Value
    The number of edges that are connected to this node.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
