ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / GetIncidentEdgeIndices Method
    Gets all the edge indices that share this node as their "from" node. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetIncidentEdgeIndices() As IReadOnlyList(Of Integer)
    public IReadOnlyList<int> GetIncidentEdgeIndices()
    Return Value
    A IReadOnlyList of edge indices.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
