ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / GetIncidentEdges Method
Example
    Gets all the edges that share this node as their "from" node. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetIncidentEdges() As IReadOnlyList(Of TinEdge)
    public IReadOnlyList<TinEdge> GetIncidentEdges()
    Return Value
    A IReadOnlyList of TinEdge.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    TIN Nodes
      // is the node "inside"
      var isInsideNode = node.IsInsideDataArea;
      // get all other nodes connected to "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinNode> adjNodes = node.GetAdjacentNodes();
      // get all edges that share "node" as a from node.
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinEdge> edges = node.GetIncidentEdges();
      // get all triangles that share "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinTriangle> triangles = node.GetIncidentTriangles();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
