ArcGIS.Desktop.Core.Portal Namespace / PortalQueryParameters Class / CreateForItemsOfType Method
The type of the portal item.
The string used for broader search on the items; such as on tags, title etc. May be empty (or null).
Example
    Returns query parameters that will find items with a specified type.
    Syntax
    Public Shared Function CreateForItemsOfType( _
       ByVal type As PortalItemType, _
       Optional ByVal search As String _
    ) As PortalQueryParameters
    public static PortalQueryParameters CreateForItemsOfType(
       PortalItemType type,
       string search
    Parameters
    type
    search
    Return Value
    Initialized portal query parameters
    Example
    Portal: Execute a portal search
      var owner = portal.GetSignOnUsername();
      var portalInfo = await portal.GetPortalInfoAsync();
      //1. Get all web maps
      var query1 = PortalQueryParameters.CreateForItemsOfType(PortalItemType.WebMap);
      //2. Get all web maps and map services - include user, organization
      // and "usa" in the title
      var query2 = PortalQueryParameters.CreateForItemsOfTypes(new List<PortalItemType>() {
      PortalItemType.WebMap, PortalItemType.MapService}, owner, "", "title:usa");
      query2.OrganizationId = portalInfo.OrganizationId;
      //retrieve in batches of up to a 100 each time
      query2.Limit = 100;
      //Loop until done
      var portalItems = new List<PortalItem>();
      while (query2 != null)
        //run the search
        PortalQueryResultSet<PortalItem> results = await portal.SearchForContentAsync(query2);
        portalItems.AddRange(results.Results);
        query2 = results.NextQueryParameters;
      //process results
      foreach (var pi in portalItems)
        //Do something with the portal items
    Requirements
