Corresponds to the "bbox=" parameter of a portal REST query. Spatial search is an overlaps/intersects function of the search extent and the extent of the document. Sorting in a spatial search is not supported. Documents that have no extent (e.g., mxds, 3dds, lyr) will not be found when doing a spatial search. Note: Document extent must be in geographic coordinates (wgs84). Using an envelope not in wgs84 will result in an exception when executing the query
Requirements
