ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / IsInsideExtent Method
The extent. This will be projected into the spatial reference of the TIN dataset. If the input envelope doesn't have a spatial reference, then the spatial reference of the TIN is assumed.
    IsInsideExtent Method (TinNode)
    Gets if this element is inside the specified extent. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides NotOverridable Function IsInsideExtent( _
       ByVal extent As Envelope _
    ) As Boolean
    public override bool IsInsideExtent(
       Envelope extent
    Parameters
    extent
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
