ArcGIS.Desktop.Core Namespace / IMetadata Interface / Synchronize Method
Example
    Synchronize Method (IMetadata)
    Updates metadata with the current properties of the item. Metadata is created for the item if it doesn't already exist.
    Syntax
    string Synchronize()
    Function Synchronize() As String
    Return Value
    Metadata xml string
    Example
    Item: Updates metadata with the current properties of the item: Synchronize
      string syncedMetadataXml = string.Empty;
      syncedMetadataXml = await QueuedTask.Run(() => metadataItemToSync.Synchronize());
    Requirements
