ArcGIS.Desktop.Core Namespace / Item Class / Synchronize Method
Example
    Synchronize Method (Item)
    Updates metadata with the current properties of the item. Metadata is created for the item if it doesn't already exist. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function Synchronize() As String
    public string Synchronize()
    Return Value
    Metadata xml string
    Exceptions
    ExceptionDescription
    Example
    Item: Updates metadata with the current properties of the item: Synchronize
      string syncedMetadataXml = string.Empty;
      // Note: Needs QueuedTask to run
      syncedMetadataXml = metadataItemToSync.Synchronize();
    Requirements
