ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / IsInsideDataArea Property
Example
    IsInsideDataArea Property (TinNode)
    Gets if this element is within the interpolation zone or the data area of the TIN. See TinDataset.GetDataArea. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides NotOverridable ReadOnly Property IsInsideDataArea As Boolean
    public override bool IsInsideDataArea {get;}
    Example
    TIN Nodes
      // is the node "inside"
      var isInsideNode = node.IsInsideDataArea;
      // get all other nodes connected to "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinNode> adjNodes = node.GetAdjacentNodes();
      // get all edges that share "node" as a from node.
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinEdge> edges = node.GetIncidentEdges();
      // get all triangles that share "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinTriangle> triangles = node.GetIncidentTriangles();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
