ArcGIS.Core.Data.Analyst3D Namespace / TinNodeCursor Class / Current Property
Example
    Current Property (TinNodeCursor)
    Gets the current TinNode in this TinNodeCursor.
    Syntax
    Public ReadOnly Property Current As TinNode
    public TinNode Current {get;}
    Remarks
    If the cursor has passed the end of the collection (i.e., when MoveNext returns false), null is returned. If a valid TinNode is returned by this property, it should be properly disposed through a call to System.IDisposable.Dispose or with the use of a using statement.
    Example
    Search for TIN Nodes
      // search all nodes that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorsearch = tinDataset.SearchNodes(null))
        while (nodeCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinNode nodeCurrent = nodeCursor.Current)
            // do something with the node
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
      nodeFilter.FilterEnvelope = envelope; //or use any other appropriate envelope
      using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorSearch = tinDataset.SearchNodes(nodeFilter))
      // search all "inside" nodes
      nodeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
      // search for super nodes only
      nodeFilter.FilterEnvelope = tinDataset.GetSuperNodeExtent();
      nodeFilter.SuperNode = true;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
