// search all nodes that intersect the data extent
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorsearch = tinDataset.SearchNodes(null))
while (nodeCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.TinNode nodeCurrent = nodeCursor.Current)
// do something with the node
// search within an extent
ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
nodeFilter.FilterEnvelope = envelope; //or use any other appropriate envelope
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorSearch = tinDataset.SearchNodes(nodeFilter))
// search all "inside" nodes
nodeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
// search for super nodes only
nodeFilter.FilterEnvelope = tinDataset.GetSuperNodeExtent();
nodeFilter.SuperNode = true;
// Note: Needs QueuedTask to run
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(null))
using ArcGIS.Core.Data.Analyst3D.TinNode node = nodeCursor.Current;
//Use the node
// search "inside" nodes with an extent
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(nodeFilter))
//use the node
var supernodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
supernodeFilter.FilterEnvelope = tinLayer.GetTinDataset().GetSuperNodeExtent();
supernodeFilter.DataElementsOnly = false;
supernodeFilter.SuperNode = true;
//Use the node
// search all edges within an extent
// this could include outside or edges attached to super nodes depending upon the extent
ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilterAll = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
edgeFilterAll.FilterEnvelope = envelope;
edgeFilterAll.DataElementsOnly = false;
using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilterAll))
while (edgeCursor.MoveNext())
using ArcGIS.Core.Data.Analyst3D.TinEdge edge = edgeCursor.Current;
//Use the edge
// search for hard edges in the TIN
var edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
edgeFilter.FilterByEdgeType = true;
edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilter))
//Use the edge
// search for "inside" triangles in an extent
ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
triangleFilter.FilterEnvelope = envelope;
triangleFilter.DataElementsOnly = true;
using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleCursor = tinLayer.SearchTriangles(triangleFilter))
while (triangleCursor.MoveNext())
using ArcGIS.Core.Data.Analyst3D.TinTriangle triangle = triangleCursor.Current;
//use the triangle
System.Object
