ArcGIS.Core.Data.Realtime Namespace / RealtimeCursorBase Class / FindField Method
The name of the field to be found.
    FindField Method (RealtimeCursorBase)
    Gets the index position for a field by name. This method can be called on any thread.
    Syntax
    Public Function FindField( _
       ByVal fieldName As String _
    ) As Integer
    public int FindField(
       string fieldName
    Parameters
    fieldName
    Return Value
    A positive integer value if the field is found indicating the index position of the field. If a field is not found with a name matching the fieldName a -1 is returned.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
