ArcGIS.Core.Data.Realtime Namespace / RealtimeCursorBase Class / WaitForRowsAsync Method / WaitForRowsAsync() Method
Example
    Asynchronously waits for new rows to be available in the internal queue of this real-time cursor. The returned System.Threading.Tasks.Task will also complete if the state of this RealtimeCursor (see GetState) changes from RealtimeCursorState.Subscribed. This method can be called on any thread.
    Syntax
    Public Overloads Function WaitForRowsAsync() As Task(Of Boolean)
    public Task<bool> WaitForRowsAsync()
    Return Value
    A System.Threading.Tasks.Task that will complete once this cursor becomes unsubscribed or new rows are available in the internal queue of this real-time cursor. The returned System.Boolean value is false if this cursor is unsubscribed and there are no more rows to be read. Otherwise it's true.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Submit a Graph Query
      await QueuedTask.Run(async () =>
        //and assuming you have established a connection to a knowledge graph
        //Construct an openCypher query - return the first 10 entities (whatever
        //they are...)
        var query = "MATCH (n) RETURN n LIMIT 10";//default limit is 100 if not specified
                                                  //other examples...
                                                  //query = "MATCH (a:Person) RETURN [a.name, a.age] ORDER BY a.age DESC LIMIT 50";
                                                  //query = "MATCH (b:Person) RETURN { Xperson: { Xname: b.name, Xage: b.age } } ORDER BY b.name DESC";
                                                  //query = "MATCH p = (c:Person)-[:HasCar]-() RETURN p ORDER BY c.name DESC";
        //Create a query filter
        //Note: OutputSpatialReference is currently ignored
        var kg_qf = new KnowledgeGraphQueryFilter()
          QueryText = query
        //Optionally - u can choose to include provenance in the results
        //(_if_ the KG has provenance - otherwise the query will fail)
        bool includeProvenanceIfPresent = KnowledgeGraphSupportsProvenance(kg);
        if (includeProvenanceIfPresent)
          //Only include if the KG has provenance
          kg_qf.ProvenanceBehavior =
              KnowledgeGraphProvenanceBehavior.Include;//default is exclude
        //submit the query - returns a KnowledgeGraphCursor
        using (var kg_rc = kg.SubmitQuery(kg_qf))
          //wait for rows to be returned from the server
          //note the "await"...
          while (await kg_rc.WaitForRowsAsync())
            //Rows have been retrieved - process this "batch"...
            while (kg_rc.MoveNext())
              //Get the current KnowledgeGraphRow
              using (var graph_row = kg_rc.Current)
                //Graph row is an array, process all returned values...
                var val_count = (int)graph_row.GetCount();
                for (int i = 0; i < val_count; i++)
                  var retval = graph_row[i];
                  //Process row value (note: recursive)
                  //See "Process a KnowledgeGraphRow Value" snippet
                  ProcessKnowledgeGraphRowValue(retval);
          }//WaitForRowsAsync
        }//SubmitQuery
    Search And Subscribe for Streaming Data
      // Note: call within QueuedTask.Run()
        //query filter can be null to search and retrieve all rows
        //true means recycling cursor
        using (var rc = streamLayer.SearchAndSubscribe(qfilter, true))
          //waiting for new features to be streamed
          //default is no cancellation
          while (rc.WaitForRowsAsync().Result)
            while (rc.MoveNext())
              using (var row = rc.Current)
                //determine the origin of the row event
                switch (row.GetRowSource())
                  case RealtimeRowSource.PreExisting:
                    //pre-existing row at the time of subscribe
                    continue;
                  case RealtimeRowSource.EventInsert:
                    //row was inserted after subscribe
                    continue;
                  case RealtimeRowSource.EventDelete:
                    //row was deleted after subscribe
                    continue;
        }//row cursor is disposed. row cursor is unsubscribed
        //....or....
        //Use the feature class instead of the layer
        using var rfc = streamLayer.GetFeatureClass();
        //non-recycling cursor - 2nd param "false"
        using (RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false))
            //etc
    Search And Subscribe With Cancellation
        //Recycling cursor - 2nd param "true"
        //or streamLayer.Subscribe(qfilter, true) to just subscribe
          //auto-cancel after 20 seconds
          var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
          //catch TaskCanceledException
          try
            while (rc.WaitForRowsAsync(cancel.Token).Result)
              //check for row events
                using var row = rc.Current;
                //etc
          catch (TaskCanceledException)
            //Handle cancellation as needed
          cancel.Dispose();
    Search Existing Data and Subscribe for Streaming Data
      //Note we can use System Task with the Realtime feature class
      //for subscribe
        using RealtimeFeatureClass rfc = streamLayer.GetFeatureClass();
        using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false);
        //default is no cancellation - use await in async method
          //pre-existing rows will be retrieved that were searched
            using RealtimeRow row = rc.Current;
            var row_source = row.GetRowSource();
            switch (row_source)
                //TODO - handle deletes
                break;
                //TODO handle inserts
                break;
                //TODO handle pre-existing rows
                break;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
