Public Function GetWkt2( _ ByVal wktFormatMode As WktFormatMode _ ) As String
public string GetWkt2( WktFormatMode wktFormatMode )
Parameters
- wktFormatMode
SpatialReference sr = SpatialReferences.WebMercator;
// Get Esri WKT
string wkt = sr.Wkt;
PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",
GEOGCS["GCS_WGS_1984",
DATUM["D_WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
PRIMEM["Greenwich", 0.0],
UNIT["Degree", 0.0174532925199433]],
PROJECTION["Mercator_Auxiliary_Sphere"],
PARAMETER["False_Easting", 0.0],
PARAMETER["False_Northing", 0.0],
PARAMETER["Central_Meridian", 0.0],
PARAMETER["Standard_Parallel_1", 0.0],
PARAMETER["Auxiliary_Sphere_Type", 0.0],
UNIT["Meter", 1.0]]
// Get OGC WKT2
string wkt2 = sr.GetWkt2(WktFormatMode.None);
PROJCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere",
BASEGEOGCRS["GCS_WGS_1984",
DYNAMIC[FRAMEEPOCH[1990.5], MODEL["AM0-2"]],
DATUM["D_WGS_1984",
ELLIPSOID["WGS_1984", 6378137.0, 298.257223563, LENGTHUNIT["Meter", 1.0]]],
PRIMEM["Greenwich", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
CS[ellipsoidal, 2],
AXIS["Latitude (lat)", north, ORDER[1]],
AXIS["Longitude (lon)", east, ORDER[2]],
CONVERSION["Mercator_Auxiliary_Sphere",
METHOD["Mercator_Auxiliary_Sphere"],
PARAMETER["False_Easting", 0.0, LENGTHUNIT["Meter", 1.0]],
PARAMETER["False_Northing", 0.0, LENGTHUNIT["Meter", 1.0]],
PARAMETER["Central_Meridian", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
PARAMETER["Standard_Parallel_1", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
PARAMETER["Auxiliary_Sphere_Type", 0.0]],
CS[Cartesian, 2],
AXIS["Easting (X)", east, ORDER[1]],
AXIS["Northing (Y)", north, ORDER[2]],
// You can create a spatial reference with the Esri WKT string or the OCG WKT2 string
sr = SpatialReferenceBuilder.CreateSpatialReference(wkt2);
// Get OGC WKT2 including authority in top-level objects
// In this case the authority is written as ID["EPSG",3857]
wkt2 = sr.GetWkt2(WktFormatMode.AuthorityTop);
DYNAMIC[FRAMEEPOCH[1990.5],MODEL["AM0-2"]],
DATUM["D_WGS_1984",
ELLIPSOID["WGS_1984",6378137.0,298.257223563,LENGTHUNIT["Meter",1.0]]],
PRIMEM["Greenwich",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
CS[ellipsoidal,2],
AXIS["Latitude (lat)",north,ORDER[1]],
AXIS["Longitude(lon)",east,ORDER[2]],
PARAMETER["False_Easting",0.0,LENGTHUNIT["Meter",1.0]],
PARAMETER["False_Northing",0.0,LENGTHUNIT["Meter",1.0]],
PARAMETER["Central_Meridian",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
PARAMETER["Standard_Parallel_1",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
PARAMETER["Auxiliary_Sphere_Type",0.0]],
CS[Cartesian,2],
AXIS["Easting (X)",east,ORDER[1]],
AXIS["Northing (Y)",north,ORDER[2]],
LENGTHUNIT["Meter",1.0],
ID["EPSG",3857]]
// Get OGC WKT2 including authority in all objects
// Authority is written as ID["ESPG",<id>] or ID["Esri",<id>]
wkt2 = sr.GetWkt2(WktFormatMode.AuthorityAll);
DATUM["D_WGS_1984",
ELLIPSOID["WGS_1984",6378137.0,298.257223563,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["EPSG",7030]],
ID["EPSG",6326]],
PRIMEM["Greenwich",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["EPSG",8901]],
CS[ellipsoidal,2],
ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["EPSG",4326]],
METHOD["Mercator_Auxiliary_Sphere",ID["Esri",43104]],
PARAMETER["False_Easting",0.0,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["Esri",100001]],
PARAMETER["False_Northing",0.0,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["Esri",100002]],
PARAMETER["Central_Meridian",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["Esri",100010]],
PARAMETER["Standard_Parallel_1",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["Esri",100025]],
PARAMETER["Auxiliary_Sphere_Type",0.0,ID["Esri",100035]]],
CS[Cartesian,2],
AXIS["Easting(X)",east,ORDER[1]],
ID["EPSG",3857]]
