ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / GetWkt2 Method
Example
    GetWkt2 Method (SpatialReferenceBuilder)
    Gets the well-known text (2) for this instance. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetWkt2( _
       ByVal wktFormatMode As WktFormatMode _
    ) As String
    public string GetWkt2(
       WktFormatMode wktFormatMode
    Parameters
    wktFormatMode
    Exceptions
    ExceptionDescription
    Remarks
    The WKT2 string is an OGC-defined international standard for well-known text strings. See Well-known text representation of coordinate reference systems.
    Example
    SpatialReference WKT2
      SpatialReference sr = SpatialReferences.WebMercator;
      // Get Esri WKT
      string wkt = sr.Wkt;
        PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",
         GEOGCS["GCS_WGS_1984",
          DATUM["D_WGS_1984",
           SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
          PRIMEM["Greenwich", 0.0],
          UNIT["Degree", 0.0174532925199433]],
         PROJECTION["Mercator_Auxiliary_Sphere"],
         PARAMETER["False_Easting", 0.0],
         PARAMETER["False_Northing", 0.0],
         PARAMETER["Central_Meridian", 0.0],
         PARAMETER["Standard_Parallel_1", 0.0],
         PARAMETER["Auxiliary_Sphere_Type", 0.0],
         UNIT["Meter", 1.0]]
      // Get OGC WKT2
      string wkt2 = sr.GetWkt2(WktFormatMode.None);
        PROJCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere",
         BASEGEOGCRS["GCS_WGS_1984",
          DYNAMIC[FRAMEEPOCH[1990.5], MODEL["AM0-2"]],
          DATUM["D_WGS_1984",
           ELLIPSOID["WGS_1984", 6378137.0, 298.257223563, LENGTHUNIT["Meter", 1.0]]],
          PRIMEM["Greenwich", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
          CS[ellipsoidal, 2],
          AXIS["Latitude (lat)", north, ORDER[1]],
          AXIS["Longitude (lon)", east, ORDER[2]],
         CONVERSION["Mercator_Auxiliary_Sphere",
          METHOD["Mercator_Auxiliary_Sphere"],
          PARAMETER["False_Easting", 0.0, LENGTHUNIT["Meter", 1.0]],
          PARAMETER["False_Northing", 0.0, LENGTHUNIT["Meter", 1.0]],
          PARAMETER["Central_Meridian", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
          PARAMETER["Standard_Parallel_1", 0.0, ANGLEUNIT["Degree", 0.0174532925199433]],
          PARAMETER["Auxiliary_Sphere_Type", 0.0]],
         CS[Cartesian, 2],
         AXIS["Easting (X)", east, ORDER[1]],
         AXIS["Northing (Y)", north, ORDER[2]],
      // You can create a spatial reference with the Esri WKT string or the OCG WKT2 string
      sr = SpatialReferenceBuilder.CreateSpatialReference(wkt2);
      // Get OGC WKT2 including authority in top-level objects
      // In this case the authority is written as ID["EPSG",3857]
      wkt2 = sr.GetWkt2(WktFormatMode.AuthorityTop);
         DYNAMIC[FRAMEEPOCH[1990.5],MODEL["AM0-2"]],
         DATUM["D_WGS_1984",
          ELLIPSOID["WGS_1984",6378137.0,298.257223563,LENGTHUNIT["Meter",1.0]]],
         PRIMEM["Greenwich",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
         CS[ellipsoidal,2],
         AXIS["Latitude (lat)",north,ORDER[1]],
         AXIS["Longitude(lon)",east,ORDER[2]],
          PARAMETER["False_Easting",0.0,LENGTHUNIT["Meter",1.0]],
          PARAMETER["False_Northing",0.0,LENGTHUNIT["Meter",1.0]],
          PARAMETER["Central_Meridian",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
          PARAMETER["Standard_Parallel_1",0.0,ANGLEUNIT["Degree",0.017453292519943295]],
          PARAMETER["Auxiliary_Sphere_Type",0.0]],
          CS[Cartesian,2],
          AXIS["Easting (X)",east,ORDER[1]],
          AXIS["Northing (Y)",north,ORDER[2]],
          LENGTHUNIT["Meter",1.0],
          ID["EPSG",3857]]
      // Get OGC WKT2 including authority in all objects
      // Authority is written as ID["ESPG",<id>] or ID["Esri",<id>]
      wkt2 = sr.GetWkt2(WktFormatMode.AuthorityAll);
          DATUM["D_WGS_1984",
           ELLIPSOID["WGS_1984",6378137.0,298.257223563,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["EPSG",7030]],
           ID["EPSG",6326]],
          PRIMEM["Greenwich",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["EPSG",8901]],
          CS[ellipsoidal,2],
          ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["EPSG",4326]],
           METHOD["Mercator_Auxiliary_Sphere",ID["Esri",43104]],
           PARAMETER["False_Easting",0.0,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["Esri",100001]],
           PARAMETER["False_Northing",0.0,LENGTHUNIT["Meter",1.0,ID["EPSG",9001]],ID["Esri",100002]],
           PARAMETER["Central_Meridian",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["Esri",100010]],
           PARAMETER["Standard_Parallel_1",0.0,ANGLEUNIT["Degree",0.017453292519943295,ID["EPSG",9102]],ID["Esri",100025]],
           PARAMETER["Auxiliary_Sphere_Type",0.0,ID["Esri",100035]]],
          CS[Cartesian,2],
          AXIS["Easting(X)",east,ORDER[1]],
          ID["EPSG",3857]]
    Requirements
    ArcGIS Pro version: 3.2 or higher.
