ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / VerticalShift Property
    VerticalShift Property (SpatialReferenceBuilder)
    Gets the vertical shift of the vertical coordinate system. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public double VerticalShift {get;}
    Public ReadOnly Property VerticalShift As Double
    Exceptions
    ExceptionDescription
    Remarks
    The vertical shift is a built-in vertical offset which is automatically added to or subtracted from each Z-value. If the spatial reference doesn't have a vertical coordinate system, then the getter returns zero.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
