ArcGIS.Core.Geometry Namespace / NonSimpleReason Enumeration
Example Example
    Specifies the reason that a non-simple geometry is non-simple. Returned from GeometryEngine.GetNonSimpleReason. See SimplifyAsFeature and IsSimpleAsFeature Wiki page. Note: This enumeration coincides with ArcObjects esriNonSimpleReasonEnum https://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#esriNonSimpleReasonEnum.htm
    Syntax
    Members
    MemberDescription
    DiscontinuousParts The geometry contains discontinuous parts.
    DuplicateVertex The geometry has one or more duplicate vertices.
    EmptyPart The geometry contains an empty part.
    EmptyZValues The geometry is z-aware, but one or more z-values are NaN.
    IsSimple The geometry is simple. Applies to all geometry types.
    MismatchedAttributes The geometry has mismatched attributes. All of the points must have the same attribute awareness. For example, if one point is z-aware and another point is not, then it has mismatched attributes.
    RingOrientation The rings of a polygon are oriented incorrectly. Exterior rings must be oriented clockwise, and interior rings must be oriented counterclockwise.
    SegmentOrientation Individual segments are not consistently oriented. The end point of segment(i) must be the same as the start point of segment(i + 1).
    SelfIntersections A path or ring intersects itself or other parts.
    ShortSegments Some segments are shorter than allowed by the system units of the spatial reference associated with the geometry.
    UnclosedRing A ring in a polygon is not closed. The end point of the last segment in a ring must be equal to the start point of the first segment in that ring.
    Undetermined The non-simple reason is unknown.
    Example
    Get Non Simple Reason
        SpatialReference sr = SpatialReferences.WGS84;
        Coordinate2D[] coords = [new Coordinate2D(5, 10), new Coordinate2D(15, 20), new Coordinate2D(25, 10), new Coordinate2D(5, 20)];
        polyline = PolylineBuilderEx.CreatePolyline(coords, sr);
        bool isSimple = GeometryEngine.Instance.GetNonSimpleReason(polyline, out NonSimpleReason nonSimpleReason);
        // isSimple = true;
        // nonSimpleReason = NonSimpleReason.IsSimple
        double resolution = sr.XYResolution;
        coords = [new Coordinate2D(0, 0), new Coordinate2D(0, 1.8 * resolution), new Coordinate2D(10, 10), new Coordinate2D(0, 5)];
        isSimple = GeometryEngine.Instance.GetNonSimpleReason(polyline, out nonSimpleReason);
        // isSimple = false
        // nonSimpleReason = NonSimpleReason.ShortSegments
        coords = [ new Coordinate2D(10, 10), new Coordinate2D(10, 20), new Coordinate2D(40, 20),
    new Coordinate2D(40, 10), new Coordinate2D(60, 10), new Coordinate2D(70, 10)];
        polygon = PolygonBuilderEx.CreatePolygon(coords, sr);
        isSimple = GeometryEngine.Instance.GetNonSimpleReason(polygon, out nonSimpleReason);
        //isSimple = false
        //nonSimpleReason = NonSimpleReason.SelfIntersections
    SimplifyOGC
      // polyline.IsKnownSimpleOgc = false
      // polyline.IsKnownSimple = false
      bool isSimple = GeometryEngine.Instance.IsSimpleOgc(polyline, out NonSimpleReason nonSimpleReason, true);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.SelfIntersections
      Polyline simplePolyline = GeometryEngine.Instance.SimplifyOgc(polyline) as Polyline;
      // simplePolyline.IsKnownSimpleOgc = true
      // simplePolyline.IsKnownSimple = true
      Coordinate3D[] coords3D = [ new Coordinate3D(0, 0, 0), new Coordinate3D(0, 1.8 * resolution, 0.8 * sr.ZTolerance), new Coordinate3D(10, 10, 1),
    new Coordinate3D(0, 5, 1) ];
      polyline = PolylineBuilderEx.CreatePolyline(coords3D, sr);
      isSimple = GeometryEngine.Instance.IsSimpleOgc(polyline, out nonSimpleReason);
      // isSimple = false
      simplePolyline = GeometryEngine.Instance.SimplifyOgc(polyline, true) as Polyline;
      coords = [new Coordinate2D(0, 0), new Coordinate2D(0, 0)];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(coords, sr);
      isSimple = GeometryEngine.Instance.IsSimpleOgc(multipoint, out nonSimpleReason);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.DuplicateVertex
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Geometry.NonSimpleReason
    Requirements
    ArcGIS Pro version: 3.2 or higher.
