ArcGIS.Core.Geometry Namespace / Coordinate2D Structure / DotProduct(Coordinate2D) Method
The input Coordinate2D to use in the dot product.
Example
    Calculates the dot product of this Coordinate2D and another Coordinate2D. Vector dot product is used.
    Syntax
    Public Function DotProduct( _
       ByVal other As Coordinate2D _
    ) As Double
    public double DotProduct(
       Coordinate2D other
    Parameters
    other
    Return Value
    A double representing the dot product of this Coordinate2D and the input Coordinate2D. The dot product is the sum of multiplying corresponding components of each Coordinate2D.
    Example
    2D Vector Operations
      Coordinate2D v = new Coordinate2D(0, 1);
      // v.Magnitude = 1
      Coordinate2D other = new Coordinate2D(-1, 0);
      double dotProduct = v.DotProduct(other);
      // dotProduct = 0
      Coordinate2D w = v + other;
      // w = (-1, 1)
      w += other;
      // w = (-2, 1)
      w -= other;
      // w = (-1, 1)
      w = v;
      w.Rotate(Math.PI, other);
      // w = (-2, -1)
      w = other;
      w.Scale(-4);
      // w = (4, 0)
      // w.Magnitude = 4
      w.Move(-1, 4);
      // w = (3, 4)
      // w.Magnitude = 5
      w.Move(-6, -1);
      Tuple<double, double> components = w.QueryComponents();
      // components = (-3, 3)
      // w.Magnitude = 3 * Math.Sqrt(2)
      Coordinate2D unitVector = w.GetUnitVector();
      // w = (-Math.Sqrt(2) / 2, Math.Sqrt(2) / 2)
      // w.Magnitude = 1
      w.SetComponents(3, 4);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
