ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / SimplifyOgc Method
The geometry to be simplified.
(Optional) The default value is false. When true, it forces the simplification code to be applied to the geometry even if the geometry comes from a trusted source or has already been simplified. When false, the method will do nothing if called on the same geometry a second time.
Example
    SimplifyOgc Method (IGeometryEngine)
    Simplifies the given geometry according to the Open Geospatial Consortium (OGC) validation specification.
    Syntax
    Function SimplifyOgc( _
       ByVal geometry As Geometry, _
       Optional ByVal forceSimplify As Boolean _
    ) As Geometry
    Parameters
    geometry
    forceSimplify
    Return Value
    The simplified geometry.
    Exceptions
    ExceptionDescription
    The input geometry is null.
    The method is not implemented for GeometryBag or Multipatch.
    Remarks
    The OGC specification is defined in OpenGIS Implementation Standard for Geographic information – simple feature access – Part 1: common architecture.
    A geometry that is simplified using this method will be simple for IsSimpleAsFeature and SimplifyAsFeature.
    Example
    SimplifyOGC
      SpatialReference sr = SpatialReferences.WGS84;
      Coordinate2D[] coords = [new Coordinate2D(5, 10), new Coordinate2D(15, 20), new Coordinate2D(25, 10), new Coordinate2D(5, 20)];
      polyline = PolylineBuilderEx.CreatePolyline(coords, sr);
      // polyline.IsKnownSimpleOgc = false
      // polyline.IsKnownSimple = false
      bool isSimple = GeometryEngine.Instance.IsSimpleOgc(polyline, out NonSimpleReason nonSimpleReason, true);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.SelfIntersections
      Polyline simplePolyline = GeometryEngine.Instance.SimplifyOgc(polyline) as Polyline;
      // simplePolyline.IsKnownSimpleOgc = true
      // simplePolyline.IsKnownSimple = true
      double resolution = sr.XYResolution;
      Coordinate3D[] coords3D = [ new Coordinate3D(0, 0, 0), new Coordinate3D(0, 1.8 * resolution, 0.8 * sr.ZTolerance), new Coordinate3D(10, 10, 1),
    new Coordinate3D(0, 5, 1) ];
      polyline = PolylineBuilderEx.CreatePolyline(coords3D, sr);
      isSimple = GeometryEngine.Instance.IsSimpleOgc(polyline, out nonSimpleReason);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.ShortSegments
      simplePolyline = GeometryEngine.Instance.SimplifyOgc(polyline, true) as Polyline;
      coords = [new Coordinate2D(0, 0), new Coordinate2D(0, 0)];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(coords, sr);
      isSimple = GeometryEngine.Instance.IsSimpleOgc(multipoint, out nonSimpleReason);
      // isSimple = false
      // nonSimpleReason = NonSimpleReason.DuplicateVertex
    Requirements
    ArcGIS Pro version: 3.2 or higher.
