ArcGIS.Desktop.Layouts Namespace / Element Class / CanApplyStyle Method
The style item to check whether its styling can be applied
Example
    CanApplyStyle Method (Element)
    Gets whether the StyleItem can be applied
    Syntax
    Public Overridable Function CanApplyStyle( _
       ByVal styleItem As StyleItem _
    ) As Boolean
    public virtual bool CanApplyStyle(
       StyleItem styleItem
    Parameters
    styleItem
    Return Value
    Remarks
    Implemented in derived classes
    Example
    Apply a style to a North Arrow
      //Note: Must be on QueuedTask.Run
      //Get the Style project items in the project
      var styleProjectItems = Project.Current?.GetItems<StyleProjectItem>();
      //Get the ArcGIS 2D Style Project Item
      var styleProjectItem =
      styleProjectItems.FirstOrDefault(s => s.Name == "ArcGIS 2D");
      if (styleProjectItem == null) return;
      //Get the north arrow style item you need
      var northArrowStyleItem =
      styleProjectItem.SearchSymbols(StyleItemType.NorthArrow, "ArcGIS North 18").FirstOrDefault();
      if (northArrowStyleItem == null) return;
      //Select a North arrow layout element
      var northArrowElement = layout.GetSelectedElements().OfType<NorthArrow>().FirstOrDefault();
      if (northArrowElement != null)
        //Check if the input style can be applied to the element
        if (northArrowElement.CanApplyStyle(northArrowStyleItem))
          //Apply the style
          northArrowElement.ApplyStyle(northArrowStyleItem);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
