ArcGIS.Desktop.Reports Namespace / Report Class / AddTemplateSubReport Method
The report template file path.
Position to add subreport. If -1, the subreport is added to the end of the report. If 0, the subreport is added to the beginning of the report.
Adjust the size of the subreport to match main report.
Specified template file is a new template.
    Adds a template subreport to the report. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub AddTemplateSubReport( _
       ByVal templatePath As String, _
       ByVal insertIndex As Integer, _
       ByVal adjustPageSize As Boolean, _
       ByVal newTemplate As Boolean _
    public void AddTemplateSubReport(
       string templatePath,
       int insertIndex,
       bool adjustPageSize,
       bool newTemplate
    Parameters
    templatePath
    insertIndex
    adjustPageSize
    newTemplate
    Exceptions
    ExceptionDescription
    The reportItem is invalid.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
