ArcGIS.Desktop.Mapping Namespace / LasDatasetLayer Class / GetActiveSurfaceConstraints Method
Example
    Gets the set of active surface constraints. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetActiveSurfaceConstraints() As IReadOnlyList(Of SurfaceConstraint)
    public IReadOnlyList<SurfaceConstraint> GetActiveSurfaceConstraints()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Active Surface Constraints
      // Note: Needs QueuedTask to run
        var activeSurfaceConstraints = lasDatasetLayer.GetActiveSurfaceConstraints();
        // clear all surface constraints (i.e. none are active)
        lasDatasetLayer.SetActiveSurfaceConstraints(null);
        // set all surface constraints active
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          var surfaceConstraints = lasDataset.GetSurfaceConstraints();
          var names = surfaceConstraints.Select(sc => sc.DataSourceName).ToList();
          lasDatasetLayer.SetActiveSurfaceConstraints(names);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
