ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ClearElementSelection Method
Example
    ClearElementSelection Method (LayoutView)
    Clear all layout elements in the layout view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void ClearElementSelection()
    Public Sub ClearElementSelection()
    Exceptions
    ExceptionDescription
    Example
    Clear the selection in a layout view
      //If the a layout view is active, clear its selection
      LayoutView activeLayoutView = LayoutView.Active;
      activeLayoutView?.ClearElementSelection();
    Requirements
