ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ZoomTo Method
The geometry defining the extent in which to pan.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
    ZoomTo Method (LayoutView)
    Zoom the layout view to the extent defined by a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function ZoomTo( _
       ByVal geometry As Geometry, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Boolean
    Parameters
    geometry
    duration
    Return Value
    Returns true if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Requirements
