ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ZoomTo100Percent Method
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
    Zoom to the layout view to 100 percent. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool ZoomTo100Percent(
       Nullable<TimeSpan> duration
    Public Function ZoomTo100Percent( _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Boolean
    Parameters
    duration
    Return Value
    Returns true if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Requirements
