ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ZoomToPageWidth Method
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
    ZoomToPageWidth Method (LayoutView)
    Zoom the layout view to the width of the page. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool ZoomToPageWidth(
       Nullable<TimeSpan> duration
    Public Function ZoomToPageWidth( _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Boolean
    Parameters
    duration
    Return Value
    Returns true if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Requirements
