ArcGIS.Desktop.Layouts Namespace / LayoutView Class / Layout Property
Example
    Layout Property (LayoutView)
    Gets the layout associated with the layout view.
    Syntax
    public Layout Layout {get;}
    Public ReadOnly Property Layout As Layout
    Example
    Activate an already open layout view
      //Activate an already open layout view.
      //A layout view may be open but it may not be active.
      //Find the pane that references the layout and activate it.
      //Note - there can be multiple panes referencing the same layout.
      foreach (var pane in ProApp.Panes)
        var layoutPane = pane as ILayoutPane;
        if (layoutPane == null)  //if not a layout view, continue to the next pane
          continue;
        if (layoutPane.LayoutView.Layout == layout) //activate the view
          (layoutPane as Pane).Activate();
          return;
    Set element selection
      //Set the active layout view's selection to include 2 rectangle elements.
      //Reference the active view
      LayoutView activeLayoutView = LayoutView.Active;
      if (activeLayoutView != null)
        await QueuedTask.Run(() =>
          //Reference the layout
          Layout lyt = activeLayoutView.Layout;
        //Reference the two rectangle elements
        Element rec = lyt.FindElement("Rectangle");
        Element rec2 = lyt.FindElement("Rectangle 2");
        //Construct a list and add the elements
        List<Element> elmList = new List<Element>
          rec,
          rec2
        //Set the selection
          activeLayoutView.SelectElements(elmList);
    Requirements
